KnowledgeBase | Forum | Contact Us | M1Files | Documents
Remote Access and Support over the Internet with TeamViewer
Customer Type - Labor
The Cust Type selection in the Order item entry - Labor dialog box opens the Customer Type dialog box which allows you to specify a labor rate for an individual line item on an order.
To select a Labor Rate for an order line item
Click your mouse pointer in one of the boxes in the Select field and click Ok. This will be the labor rate that will be applied to the order line item.
Related Procedures:
Setting a Customer's Labor Rate
Setting a Shop Labor Rate
