KnowledgeBase | Forum | Contact Us | M1Files | Documents
Remote Access and Support over the Internet with TeamViewer
Copying an Inventory List Item
An easy way to create a new inventory item is to copy a similar existing item and simply change those fields that are different.
To copy an Inventory item:
1.     In the grid of the Inventory List dialog box, click your mouse pointer on the part you wish to make a copy of.
        The grid line for the part is highlighted.
2.     Select Copy.
        A dialog box asks you to confirm your request.
3.     Select Yes to create a copy of the part record.
        A copy of the part record appears in the Inventory List grid.
        {bmc COPY.BMP}
4.     Double-click your mouse pointer on the copied record.
        The Edit Part dialog box appears.
5.     Change the Part Number and/or description and edit any other fields, as necessary.
6.     Select OK.
        Your new inventory item is now available for placement on Manager orders.
See also...
Inventory List
