Shop Management Software Repair and Estimating (Desktop) OnDemand5.com PerformanceCenter Using Management Forum
Learning Tools Product Orientation Webinars
PerformanceCenter PerformanceReports Login
CRM eCRM ServiceIntelligence
Contact Mitchell 1
    Estimate/Repair Order/Invoice Validations
Before you can print an estimate or repair order, Manager checks for missing information. All checks for missing information must be completed before you are able to print. The Estimate/Repair Order Validations dialog box is where you will select/deselect the individual checks that you want Manager to conduct before printing an estimate or repair order.
To change Estimate/Repair Order Validation settings:
1.     Select Estimate/RO Validations from the Shop Data Setup table (which is available from the Setup menu).
        The Estimate/RO Validations panel displays. The function of each setting is clearly explained in its respective title.
2.     Toggle warnings as desired.
3.     Select Done to save your entries and exit.
        Invoice Validations
        Before you can print an invoice, Manager checks for missing information. All checks for missing information must be completed before you are able to print. The Invoice Validations panel is where you will select/deselect the individual checks that you want Manager to conduct before printing an invoice.
To change Invoice Validation settings:
1.     Select Invoice Validations from the Shop Data Setup table (which is available from the Setup menu).
        The Invoice Validations panel displays. The function of each setting is clearly explained in its respective title.
2.     Toggle settings as desired.
See also...
Invoice Validations
